exiledinaz
I am very happy to have had my injector pump replaced recently. However after the replacement, my exhaust brake does not function while cruise control is activated. (It is in Tow haul and tried it both in full exhaust brake and auto exhaust brake) Two others on this board are having issues with the exhaust brake AFTER the Y78 recall was done. Not the exact issue, but exhaust brake not working as it did. The only thing done besides the mechanical R&R of the pump was a re-flash on the computer. The dealer has already replaced the cruise control switch saying it showed faulty. No change in exhaust brake etc. I have contacted RAM customer service and get the standard " Go to your local dealer and have our highly trained techs look at it". I am going to attempt that route again for the second time in June. For now I will just have to throttle myself down hills etc to activate the exhaust brake. If you have had your injector pump replaced on the Y78 recall and the exhaust brake is not functioning as it was or should, please post here so RAM cares can see it. TIA. I have a 2020 RAM 3500 HO with Aisin trans.
