Jesus perdomo
I have a dodge ram 3500 diesel 6.7 and when I go with 10k pounds of weight the temperature increases to 230f who helps me because it goes up so much
You have to give us way more info like:I have a dodge ram 3500 diesel 6.7 and when I go with 10k pounds of weight the temperature increases to 230f who helps me because it goes up so much
Is that towing up steep grades?
yes the refrigerant is fullWhat year? How many miles?
Have you verified the coolant is full?
Whats the ambient temp outside?
Is that climbing a hill or just flat land driving?
Anything obstructing the grill?
And when the temp goes over 220 do you hear the fan going full speed?
Any modifications to the vehicle?
Also dont post the same question everywhere and multiple times it really makes it difficult to follow and give you the help you need. I will ask a Mod to merge all the posts for you
It only does it when I'm carrying a heavy trailer or has anything obstructing the grill if I hear the fan go full speed when it's over 220You have to give us way more info like:
YesIs that towing up steep grades?
2010 Year 220k miles
Thank you very much for your answer. Do you mean that I changed the thermostat to one of 190 and the temperature is fine like this?You posted in a section for 2019+ trucks.
The 2010’s use a 200° thermostat. Is that what is installed still?
There isn’t not a lot of specs published on the 210° thermostat, since it’s not a normal ISB thermostat, but based on the 180° and 190° thermostats the following is likely close enough to work with.
Cracks at 210°, full open around 217°, max allowable around 235°. I would expect to see around 225° when working it hard.
Verify the radiator is clean inside and out, and that the fins aren’t damaged at 220K.
Bottom line is that the temps aren’t that hot for a 200° thermostat.
Thanks, how much can be the maximum that is in climbs?You are fine with your 2010 truck. 230 is about normal pulling up grades
If it goes over 240 i would slow down and let it cool off.Thanks, how much can be the maximum that is in climbs?
Dont change the Tstat to 190 keep the 200 its like that for the emissions systemsThank you very much for your answer. Do you mean that I changed the thermostat to one of 190 and the temperature is fine like this?
Isn't the ideal temperature anything before a systems warning light coming on?
These trucks will not self destruct if you work them hard. If a parameter reaches its threshold then you will know.
Try and focus on the road and not a gauge.
I'd agree with all of the above, however 230 is excessive. I towed 14k lbs 5'er through the Nevada desert in July 2 years ago -- 110* temps. My coolant temp never went much above 220... fan would kick on and bring things back into the low 200's pretty quickly.
Again, if the truck ain't complaining.........
