with the upgrade to 26.17, you're going to loose your offroad pages or whatever its called.FINALLY got my hands on the module to replace the junk 8.4 Non-Nav in my connected services deleted truck. I've had the screen, bezel, and harness is my office closet for whats felt like forever. Got it updated to the S26.17 in the upgrade post and so far has been a vast improvement. It seems to handle higher quality audio sources better over wireless carplay and it doesn't have a stroke if I try to use my 360 cameras while carplay is also running. I do miss my physical controls and didn't mind the 8.4 form factor, but being a connected services delete I got shafted with the R1 Low.
I still very much have off road pages on mine. The module I was able to source shipped with 23.something on it, updated to 26.15 then factory reset, updated to 26.17 then factory reset, then updated my maps. AFAIK it's mostly been folks who have connected services that have those gremlins. Being a rona build I don't have any of the LTE stuff (connected services) nor do I have the BSM sensors in my tail lights. Only thing I changed in my BCM were the two configuration items to make the change from the 8.4 with physical controls to the 12.1. That said I did previously enable the front camera and guidelines in AlfaOBD, but even then that didn't give me off road pages in my 8.4 w/o NAV.with the upgrade to 26.17, you're going to loose your offroad pages or whatever its called.
Any plans on selling the 8.4" screen?FINALLY got my hands on the module to replace the junk 8.4 Non-Nav in my connected services deleted truck. I've had the screen, bezel, and harness is my office closet for whats felt like forever. Got it updated to the S26.17 in the upgrade post and so far has been a vast improvement. It seems to handle higher quality audio sources better over wireless carplay and it doesn't have a stroke if I try to use my 360 cameras while carplay is also running. I do miss my physical controls and didn't mind the 8.4 form factor, but being a connected services delete I got shafted with the R1 Low.
