The one on the BFG site for their A/T KO2's. Went to my size, 35X12.50R17 and clicked on it. And it came up with the load value at different pressures starting at 25 PSI and going up in 5 PSI increments.
At 25 PSI, the combined weight load of the 2 tires (3750) is more than my rear axle weight of my truck (3080). So that's why I said 20 PSI.
Gotcha, makes sense.
The lower pressure is the minimum pressure recommended, regardless of lower weight.
I run into the same issue. I’ll only go below the min published pressure, 35 for my tires, if I won’t be driving at highway speeds and it’s cold out. It’s great for added traction on snow/ice or improved ride on FS roads.
