A bit a modified idea from
@whitexc regarding the Furrion Camera, he tucked his wires into the sunglass holder.
I will say these clips on either side of the mirror pod are on there *good*.
Once that was loose, it was marginally easier to removed the center trim piece, but it still involved a significant amount of cursing.
Then came the Donger adaptor and a USB to 12V adaptor.
The 12V plug on the dash is normally occupied with the power to the Garmin... and while I could run another USB cable down, it starts to get cluttered.
I used some electrical tape to make sure the two 12V plugs stay connected, rolled up/zip tied the excess wire and laid it flat along the passenger side of the mirror pod.
There is *just* enough room for it to lay flat between the two clips.. I was originally going to just lay it at the bottom of the pod, but I thought it would get in the way of the black box/senor looking thing.
I did a quick test drive and no warning bells... center trim is currently not attached, I will be using the camper this weekend so if the test run/drive works, then I'll button it all back up.
