Awesome! Lets hope they work with you!Update: So far dealer has been pretty receptive. Has arranged for tow to local dealer.
Imagine that right there in the first post!
Im just busting your balls lol.Ok, my bad. Its been awhile since I read the first post. Just wondering and asked. my bad. No need to be a smart ass!!!
We appreciate being tagged in this! It's the best way to get ahold of us.if the dealer doesn't take care of this, like, immediately upon rcvg the vehicle, leverage @RamCares folks for guidance. this is a pretty obvious case of bad fuel.
Does anyone drain their fuel/water filters on a regular basis even if the water in fuel light is not illuminated?
Nope in over 30 years running all sorts of diesels i have not and i have never had WIF light come on eitherDoes anyone drain their fuel/water filters on a regular basis even if the water in fuel light is not illuminated?
Even taking some and putting it on a surface to dry for a couple hrs if you see the crystallization happening then you know its DEF but usually the smell alone is enough to know if you take a sample of it when the diesel is separated from the waterCouldn't you test the water that was drained from the filters, using a DEF refractometer, and verify that it is or is not DEF? That should at least give you a path to follow.
