Sorry for the tread revival but great info here, my buddy has a 19 1500 with the bins he does not want so i am transplanting them in to mine thankfully i have his truck to measure off of for the carpet cuts
I like mine for emergency supplies…spare quart of oil, funnel, small tool kit, jump start pack, etc. Not stuff I’m accessing on the regular, but there if I need it.I hope you find good use for them. I ended up not using them, mainly due to being odd sized and I aint gonna pull up the 1pc mat everything I need access. it's a great idea for sure.
Mainly small ratchet straps and some other stuff thats currently under my back seatI hope you find good use for them. I ended up not using them, mainly due to being odd sized and I aint gonna pull up the 1pc mat everything I need access. it's a great idea for sure.
If i had the split seat i would since i removed my cross bed tool box i need a bit more interior storage. I do have the one piece mat but its no biggy lifting the side up enough to get in the boxI keep all that under the seat. do yall run the 1pc rear mat?
Im in canada so thats a no go hereKeep a 938 among other stuff in mine, the Weathertech hides the box a bit so like it that way.
I did not find them that bad luckily. The only issue i see is i will have to move my seat forward to open the drivers side bin because the lid hits the seatnice. I had to trim the foam for the same reason, but you'll get em flush. those block off plates were a bear.
Was this a 1500 classic or a 5th gen? I thought the bins were different on the 5th gens.Sorry for the tread revival but great info here, my buddy has a 19 1500 with the bins he does not want so i am transplanting them in to mine thankfully i have his truck to measure off of for the carpet cuts
Classic 4th genWas this a 1500 classic or a 5th gen? I thought the bins were different on the 5th gens.
Also I use the bin behind my driver seat for storing my gooseneck ball and safety chain puck things. Don't remember what I have in the other bin, the heavy ram floor mat I put in the back makes it a bit of a pain to get into the bins and I've always got the flat floor things folded out for my dog.
