2019 ram 2500 6.7 Cummins
Randyortiz79
I have a 2019 ram 2500 which i am in the process of putting bypass cable for a weight reduction. I have a plug with 2 orange wires in the place of where the bypass cable is supposed to go in. any ideas of what this connection is for and can I just disconnect it?
In the canbus block? Or the OBD2 port? Did you buy the truck new or used?
It’s run towards engine bay and is connected to another wire labeled CAN B
Do you have power steps by chance? Either way you can plug your bypass cable to the spot below the 5th spot like the tuner recommends
No I don’t have power steps. And I believe it’s in the same spot that I’m supposed to connect to.
You can put it anywhere in that block really the instructions just say #5 as it is usually always open on every truck
