Electronut
Setting up on my 2500 6.4L gaser with Rear Air Suspension tomorrow. Bought the GenY Boss 10k Torsion Shank with 9.5 inch drop to accommodate the 35's with 2" Thuren leveling kit. Sucker is HEAVY! Still have to bolt up Equalizer head too...yikes.
Have 27' TT that will gross out at a round 7800 lbs with a hitch weight of about 900-1000lbs give or take some weight there.
I was going to measure every necessary step along the way. Truck bare, TT hooked w/no WD bars and then with to see how much WD there is and adjust accordingly.
I was going to handle above while truck is in tire jack mode so shuts the rear air off.
Was hoping to get an idea for starting point on the height position of the L brackets(amount of WD) I should use and how much sag the truck will have when hooked up with no WD bars(again air system off) . This will give me a better idea from the get go how high I should place my hitch ball height too before I start the process. Don't know what to expect for rear sag on 2500 with factory air when turned off.
Want to distribute 50-100% of the weight to front as guided by Equalizer and without the Rear Air kicking in to level off. The air can then make up any difference afterward once additional passengers and bed cargo is loaded up. That's the beauty of the Ram Air which I'm looking forward to see it do its thing.
Any insight appreciated.
