Front tow hooks are more than sufficient and very strong.
Otherwise you are looking at something mounted underneath and the lower valance will likely interfere.
I would try and find some OEM tow hooks and install them as any aftermarket will likely be part of an after market bumper
He has a 4th gen id assume because its in the 4th gen section but also they are not safe to use as a recovery point they have very low weight ratingThere's this.
Didn't notice 4th gen thanks, he also said use bumper....I'd take this over that as recovery point any day lol.He has a 4th gen id assume because its in the 4th gen section but also they are not safe to use as a recovery point they have very low weight rating
Before I replaced the bumper on my 4th gen, I'd installed some replacement tow hooks similar to these, as the prior owner had replaced OEM hooks with a LED bar that took up the whole lower opening:
There's this.
Any suggestions for aftermarket front recovery points? (I will continue to use stock bumper)
Found something suitable - at least i can now attach a recovery strap via shackles
