Looks like maybe light flashing? If you have the factory VSIM or add it you can activate the wig wag feature. Not all the combos they are offering but it’s factory![]()
I have one for my 2019; relatively easy way to adjust tire diameter to correct the speedometer, adjust TPMS threshold, prevent fog lights from dropping out when turn on high beams, etc. You can do these things with a computer and alfaOBD too but this is a bit easier for beginners/no computer needed.What does it do / used for?
I would get the bypass cabe that plugs in to the can bus over the SGW bypass module so you dont have to pull the dash apart
Where can I get that ? Care to share some links? I already ordered the SGW bypass Module but I’d rather not have to break everything when I go to the dealership for service
Security Module Bypass | KaodTech
Will Ship 3-5 Business Days after OrderIf you have a 2018 - 2024 RAM and would like to perform diagnostics or make changes to the modules of your truck using tools like AlfaOBD or AutoEngenuity, this bypass is for you.Does this allow access to all modules?It has been tested connecting to the BCM...www.kaodtech.com
any alternativesSend me a pm, and I can get one built for youThat’s out of stockany alternatives
I am currently in the process of getting this thing to work, I have a ram 3500 2022 with the 12” touchscreen and my issue is that when I plug the obd2 port in my stereo/radio it glitches every 5 seconds or so. Also, it does not come with any light patterns, you need to plug it into a windows computer (Mac does not work). Still waiting to get it plugged into a computer but I’m a little worried about the glitching with the screen when plugged in. Btw this was installed by a professional.Has anyone used the Z flash on 2022 or 2023 2500? I’m fixin to order one for myself want to know if it still works their website only lists till 2021
