Electronut
Just finished this wrenching and not sure if anyone ever shared the results but figured I would on my rig. Brand new truck with 80 miles recorded on odometer. Measurements taken on OEM stock setup and then again when changed over to Thuren 2" Front coils, Thuren Track Bar, Fox ISP 2.0 shocks tuned directly from Thuren, and Thuren links in rear since I have Ram Air from factory. Measurements are from center wheel hub to top of fender.
Stock OEM setup
Passenger Side:
Rear - 25 3/4 inches
Front - 24 3/4 inches
Drivers Side:
Rear - 25 9/16 inches
After Thuren Products Install
Passenger Side:
Rear - 27 2/16 inches
Front - 27 inches
Drivers Side:
Rear - 26 3/4 inches
Front - 27 inches
In summary, front lift was exactly 2 1/4 inches. But I'm sure will settle little more after some driving. The rear dims on my truck were weird from the start being driver and passenger side were already roughly 1/4 inch difference. I tried adjusting the rear drivers side up another 1/4 to 1/2 inch by slighlty extending that side air link but little bit I threaded out it didn't trick the sensor to fill the bag little more. I'll drive the truck a little and let things settle and will fiddle with some more. By eye you can't tell that 1/4 inch difference anyway and would rather a little bit of a higher rake though when towing our travel trailer even though Ram Auto Leveling should keep as it is. I'm just being particular about.
Perhaps this helps others that need real stats.
Stock OEM setup
Passenger Side:
Drivers Side:
Passenger Side:
Front - 27 inches
Drivers Side:
Front - 27 inches
