CortexM0
I found 3C6UR5SLXPG518688. It has the DRVM 3.0 without the tow mode camera. It appears to also have the port on the bumper.I have since found out that all 2023 DRVM equipped trucks use the same 3.0 DRVM, and they all have the camera processor. The cameras they use are different part numbers than the cameras that the 21-22 DRVM uses, so I’m not sure.
I don’t see a 2023 wired tow mode camera kit part number, but I do see the part numbers of the individual parts contained in the kit.
If the regular DRVM and the 3.0 both use the same mirror and video processor, then unless I'm missing something, the only hardware difference between the regular DRVM and the 3.0 are the cameras in the side view mirrors. I'm guessing there would be several members interested in a 3.0 upgrade, if they could do so without needing the trailer reverse steering.
This is from a slightly older document, but do these component numbers match up with current part numbers?
If so, the kit part number may be 68586112AA But I can't find reference to this part number anywhere else...
