Taller tires not sticking out
Torqued
Please post some pics of 35" tires that aren't sticking out of the fender wells. Brand, size, and offset of wheels? Brand, and section width of tire. Most 35 inch tires are 12.5" (much wider than stock) I'm looking for dually pics. I'd like to see 20, 22, and 24 inch wheels.
Not many (if any) are on here with such large diameter rims, most know the downfalls of such a small sidewall on a heavy duty truck.
taller tire will not stick out. wider tire will. But it also depends on the offset of the rim.
I kept my stock 17" bead lock rims on my PW and put BFG 35x12.50 on them and they do not stick out.
Since your thread title doesn't mention specifically that you're looking for a dually, you may be better off searching through a few of the posts that are specific to dually wheel/tire combos.
If you run 35x12.5 on a +25mm it will come out flush to the fender.
My post does say I'm looking for dually pics. Maybe I should have put that in the title
My oversized tires do not stick out beyond the fenders on my dually, but my wheel and tire set up are still 17" and won't help you any.
I have a ‘22 PW stock Beadlock rims. Do you know what the offset on them are? I’ve found several stock offset numbers ranging the gamut of +24 all the way to +59
I’m looking for around 2-3” of poke but can’t find a solid number for the Beadlock rims. 17x9 ?? Offset
You wont find many if any dually wheels here that are 22 or 24” even 20s are not very common. There is a thread here somewhere about dually wheels and larger tires with a bunch of pictures you can try and find
As you have found, information on the interwebs concerning offset for stock Ram wheels is all over the place with wrong information in many cases.
Start from scratch:
Start from scratch:
The only issue with that is the tire sticks out further than the wheel most if the time so unless you break a bead you are not going to be 100% accurate but it will get you close
debating 285/75R18's 0.4" wider than stock, but 1.6" taller than stock and 0.2" more than 35's as at least the Falken AT3W's measure 34.6 not 35!!
If it's going on a PW. that should look good. I like mine to poke a bit I would have liked a 0" offset so they would be just a bit more out. But I think it looks just fine how it is.
