No setup option for Trailer Tire Pressure.
Phil T what radio software are you running on your 2019?
How do you get to what version we have?
2019 OpenRange 3X427BHS
Hold the outer two buttons on the lower portion of the display for 10s. Then press “radio part info”
Picture I have displayed is the page that shows up.
JD
2019 2500 Ram CTD 12”
Got it. Thanks.
Did you just recently enable the settings? It takes a while for the radio to pull the BCM configuration. Pull the radio fuse and let it sit for 15-20 minutes. Reinstall the fuse, and do a few drive/shutoff cycles. See if the settings show up then.
Got it. Thanks.
Looks like you and I have identical configs. Will be interested to see what we need to do to make the TTPMS setup option appear on the radio once you are all setup Hoff. Have you setup your TTPMS on the radio yet? Did it show up for you?
I am not getting any errors on the vehicle side so I assume that means the truck can see the TIM and TTPMS Receiver.
Not sure how the radio decides what options to show or how often it polls the BCM for setup. I wonder if resetting the radio defaults would force it to look at the BCM settings. Anyone have any ideas on this?
Thanks Jimmy. I will try that.
Is the radio on the “Instrument Cluster” fuse? F49? I don’t see it called out specifically.
I’m waiting for a TIM and Cable. Should have both soon.
Got everything else. Even Mopar sensors, but hoping it picks up my other sensors since they are on same frequency.
What crazy person designed that? That’s crazy??
It’s in the wiring all by itself outside the fuse box-
Jimmy, I see two inline fuses. One on a bundle that connects to the front of the PDC one that connects on the back. I had to lift the PDC up to see either. Do you know which it is. I cant tell from the diagram.
Hoff can you send me a picture of the trailer setup page where you get to the TTPMS setup?
Also, do the options disappear when the trailer is not attached?
I don’t think I have that yet. Don’t have a TIM installed.
But you are getting the picture on the instrument cluster. I am getting:
It’s coming out of the bottom of this bundle
If you have the sensors installed in the trailer, hook up the trailer. Start the truck. Go to the uconnect screen. Select trailer brake. The tire setup is in there. Once you start the setup, it will prompt you to let air out of each tire in order. When the horn beeps, it found the sensor. Then move to the next one until all tires are registered. Really easy.
Did that. Didnt get the setup option on unconnect. Got the fuse out of the radio. Going to reinstall it and see if it appears. Dropped the fuse trying to reinstall it so now I got to guy buy one...
Do your software settings match mine Phil?
When you reinstall the fuse, you will initially be missing a bunch of settings. You have to drive the truck a few times, shutting it off in between, and open/close the drivers door. Then all the settings will appear.
