How do you get to what version we have?
2019 OpenRange 3X427BHS
Did you just recently enable the settings? It takes a while for the radio to pull the BCM configuration. Pull the radio fuse and let it sit for 15-20 minutes. Reinstall the fuse, and do a few drive/shutoff cycles. See if the settings show up then.![]()
No setup option for Trailer Tire Pressure.
Phil T what radio software are you running on your 2019?
Got it. Thanks.![]()
It’s in the wiring all by itself outside the fuse box-Is the radio on the “Instrument Cluster” fuse? F49? I don’t see it called out specifically.
Not sure. That’s how it’s been since 2009What crazy person designed that? That’s crazy??
It’s in the wiring all by itself outside the fuse box-![]()
I’m waiting for a TIM and Cable. Should have both soon.
Got everything else. Even Mopar sensors, but hoping it picks up my other sensors since they are on same frequency.
I don’t think I have that yet. Don’t have a TIM installed.
Jimmy, I see two inline fuses. One on a bundle that connects to the front of the PDC one that connects on the back. I had to lift the PDC up to see either. Do you know which it is. I cant tell from the diagram.
If you have the sensors installed in the trailer, hook up the trailer. Start the truck. Go to the uconnect screen. Select trailer brake. The tire setup is in there. Once you start the setup, it will prompt you to let air out of each tire in order. When the horn beeps, it found the sensor. Then move to the next one until all tires are registered. Really easy.But you are getting the picture on the instrument cluster. I am getting:
When you reinstall the fuse, you will initially be missing a bunch of settings. You have to drive the truck a few times, shutting it off in between, and open/close the drivers door. Then all the settings will appear.Did that. Didnt get the setup option on unconnect. Got the fuse out of the radio. Going to reinstall it and see if it appears. Dropped the fuse trying to reinstall it so now I got to guy buy one...
Do your software settings match mine Phil?
