Riddick
Thuren front sway bar installed. Very straight forward swap. Hardest part for me was getting my grease gun to work properly. Outside of that bar looks great, no driving impressions as of yet. However, if it performs as good as everyone says, I will be more than happy.
My only advice on install would be the type of grease you use. The directions do not say but I highly recommend a full synthetic lube such as super lube. If you run a petroleum based grease it will deteriorate the poly bushings. I made sure to lube the sleeves and bushings prior to install as well as a few squirts from the gun once installed.
Big thanks to @Gondul for helping out with sleeve orientation.
