Whatever rub you get will be very very minor, you can trim but you don’t need to. you will not rub on the control arms.
I‘m running the pin top with AEV wheels and I’m not going to trim. Thought I would but it’s really not an issue.
Thanks man..
They are made in Finland. They are outstanding snow/ice tires. Mine are studded and as others have said, they are like cheating. Highly recommend them.
not saying they are not made in Findland but does the sidewall actually have made in findland on it?
Just for giggles what did you pay? They are $500 a pop Canadian before install. :eek:
Yeah, they arent cheap. I paid $320 US each for just the tires without studs (because I couldnt find any place that had the studded ones) and then another $25 per tire to get the studs installed at the shop (plus all the other install charges).
@austins_dreams
37s stock wheels and stock height. So far no rubbing I can see but I'm sure they will rub off roading. Will keep an eye. Coopers are a nice ride so far and truck feels great. Might paint the bead lock plates black but not sure yet.IMG-1022 (1).jpg
37s stock wheels and stock height. So far no rubbing I can see but I'm sure they will rub off roading. Will keep an eye. Coopers are a nice ride so far and truck feels great. Might paint the bead lock plates black but not sure yet.View attachment 50754
Try hyperdip they have a nice red color. If you don’t like it, you can remove it. If you do like it, it holds up better than you’d think.
Looks nice. I missed my factory beaklock rims w/ 37's, I loved the look with the tires tucked in nicely. Butt I was just getting too much rubbing. Running Method 704HD's which are the 18 offset simliar to the AEV's I know rub on plastic when in reverse and turning but not dailying driving which is nice. The Plastic in reverse is just some trimming or re-molding. The other rubbing was on the radius and track bar -- little harder to mod those ;)
