I just went through this with my dealer, my screen said my tires were around 90 on my test drive, I expected the service/prep guys to go over the pressures and back them down, they did not.
I looked up the tire specs on the Firestone site and when I plugged in my truck it came back with essentially what the door sticker had stamped on it. I pulled the tires down from almost 90 cold to 65 each and haven't looked back. Max sidewall is stamped at 80 cold, this is where it's so misleading, engineers state a max pressure on a tire so starting at 80, tires creep up to what our mind thinks is dangerously high say 95psi. In speaking with a Tire Tech from Goodyear at a NASCAR race here in Phoenix, I asked him about that and he said it's confusing to him and he's in the business! He said the tire is not going to burst at 90 or even 100 which is about the highest it would get starting at 80 but he felt the info on the sidewall does confuse more than help.
Check your recommended pressures at -
https://www.firestonecompleteautocare.com/tires/tire-pressure/
If not rolling on Firestones, check the tire manufacturer site, they should have something very similar, I also found something on TireRack.
Incidentally, don't do what I did on my first tow when I got my 2016 a few years ago. I left the house with what was stamped on my door, 65/80 F/R cold, with the travel trailer on the bumper, a bed packed with camping gear, my better half and 3 dogs in the back seat we drove for about an hour and I decided to check pressures, no alarms, just my mind wanting to make sure thing were ok. The rears were up to about 94/95 and I freaked out, pulled into the 1st discount tire I found and asked him to back them down to 80, in about an hour they crept back up to about 94 from what I recall and armed with a pressure gauge I backed out pressure to get them back to 80. The rest of the trip was unnerving, to say the least, would we have a blowout, were the tires OK, they were brand new just installed a day or two before, did I have a good spare... you get the picture.
Bottom line, I should have left it be, I've been told by professional long haul drivers that what I did was create a bigger issue for myself, the tires would have been fine and at 94'ish they were about as maxed out as they would be and next time don't touch them.
All the best!
