Rockwell makes nice hardened gears for them aswell if you ever need a strong rebuild.Brand new transmission for the YJ.
yes, Aisin still makes AX15s you can get them straight from the factory with warranty.
First piece of the build that will be collecting in the garage.
Very niceMy 84 Jeep Scrambler
Awesome i have been trying to find one for years i may end up making my own from a CJ7 they are awesome machinesMy 84 Jeep Scrambler
You could practically build one out of a catalog now. Mine is authentic, but is so far from stock that it doesn't even matter anymore.Awesome i have been trying to find one for years i may end up making my own from a CJ7 they are awesome machines
I never order lol thats too easyYou could practically build one out of a catalog now. Mine is authentic, but is so far from stock that it doesn't even matter anymore.
Those things are remarkably capable with a little bit of work.Just the wife’s work beater…tried to snow wheel it…it didn’t like it.View attachment 50347
Wow! Must be a real challenge to get that much power to the wheels in a FWD car??So I picked up a little Honda Civic last year around spring... maybe late winter. Kicker is, it was a fully built, e85, 430hp ripper. I kicked its ass for about 4 months before she had enough and dropped a valve destroying the nicely ported cylinder head along with piston #4, and the block being it cracked the sleeve/water jacket through and through.
Ugh.
So... on to the build. Yank motor out, source new (used) longblock for $300 lol. Tear it down, send head to machine shop along with block.
While im in there... upgrade turbo to a nice Borg Warner s252sxe that should be good for about 500-525whp.
With an luck, ill start putting her back together in early Feb.
Still waiting for OEM oil pump, water pump, and timing belt/tensioner. Also waiting on new pistons and MLS head gasket.
Unreal!!!!! Bet that little sucker can scatIt is.
Cool part is this car has programmable boost by gear. In 2nd gear it sees about 14 psi... enough to burn the tires, but not as much as you'd expect. 3rd gear sees 20 psi --fights for traction, but has plenty of it, 4th gear gets the full 27 psi.
I haven't had it at the 1/4 mi track, but there's no reason the little shlt doesn't trap at or near 130 mph.
That’s a cool carSo I picked up a little Honda Civic last year around spring... maybe late winter. Kicker is, it was a fully built, e85, 430hp ripper. I kicked its ass for about 4 months before she had enough and dropped a valve destroying the nicely ported cylinder head along with piston #4, and the block being it cracked the sleeve/water jacket through and through.
Ugh.
With any luck, ill start putting her back together in early Feb.
My first Jeep (and first new vehicle purchase) was an ‘03 Liberty. It ended up with a 3” lift, 32s, rock sliders, full underbelly skids, onboard air, and a bunch of other stuff. Wheeled it all over the NE and Moab. Finally sold it when a 10 cent c-clip gave out in the tranny and it ate itself. It was a fun little vehicle, and a blast to show the haters that you *can* wheel with IFS. That 3.7L inhaled gas faster than a Hemi though.
