After buying my 2020 ram 2500 diesel with 13600 I discovered the original owner installed Firestone Airbags. I want to put it back to stick as I don't trust Airbags as the sole suspension source.let me know if you have coils and how much thanks
Are you sure the bags are replacements or supplemental?After buying my 2020 ram 2500 diesel with 13600 I discovered the original owner installed Firestone Airbags. I want to put it back to stick as I don't trust Airbags as the sole suspension source.let me know if you have coils and how much thanks
Sounds like you still have the factory springs too.and the airbags are just for extra capacity. Do you have a picture of the rear end setup?Well they are Firestone brand and the airline job isn't great looking and the single fitting is drilled through the rear bumper plastic by the license plate lol
Just take a look directly under from the rear of the truck. You should see the airbags and then directly inboard of them two coil springs.Well they are Firestone brand and the airline job isn't great looking and the single fitting is drilled through the rear bumper plastic by the license plate lol
That's just absurd for you to say..like I don't know how the stock suspension is...ffs....the rear coils are gone and replaced with a Firestone airbag system..Just take a look directly under from the rear of the truck. You should see the airbags and then directly inboard of them two coil springs.
Easy there tiger. Tons of very knowledgeable people on here trying to help you out but are just looking for some context firstThat's just absurd for you to say..like I don't know how the stock suspension is...ffs....the rear coils are gone and replaced with a Firestone airbag system..
Post some pics up then - none of us have ever heard of a setup you're describing so as @H3LZSN1P3R said you're either wrong or have a completely insane setup that should not exist. And how am I supposed to know your level of "expertise"? For all we know you're some sort of joe-blow that doesn't know the difference between your fuel filler and the radio knob....That's just absurd for you to say..like I don't know how the stock suspension is...ffs....the rear coils are gone and replaced with a Firestone airbag system..
Kelderman does not list a bag brand so it could be possible but who in their right mind would run that setup without a compressor or without a dual line setup if they are not supplemental bagsit may be a kelderman set up of its truely full replacements. they use firestone bags, i thought.
a pic is worth a thousand posts.
Well, you bought a used truck without looking underneath it so we assumed you were clueless.That's just absurd for you to say..like I don't know how the stock suspension is...ffs....the rear coils are gone and replaced with a Firestone airbag system..
yup!.... who in their right mind would run that setup without a compressor or without a dual line setup if they are not supplemental bags![]()
