Fog Light connection to Auxiliary Switch ?
HEMIDUTY
I am going to wire the aftermarket fog lights to the aux switch. My question is the aux fuse box has relays for the aux switches already and my fog light wires also has a relay, would it make sense to eliminate the relay on the fog light wires being there is already one in the aux fuse box? Thanks
Yes, you only need to run one relay/fuse for your installation.
That’s the beauty of the Aux switches. It’s all there for ya. Just run the wire out of there to the lights, ground them and you’re done.
I haven't had any luck finding fuses smaller than 20A. 2 of my circuits only need 3-5A fuses.
I haven’t looked for smaller fuses than 20 amp, I probably should have a 15 amp on one of mine, but the other 2 required a 20 amp…
Late bump for clarity:
In this case, where you are utilizing the Aux switches and built in relays, but the accessory calls for a smaller fuse, would a inline small fuse be good?61X5WuttyVL.jpg
In this case, where you are utilizing the Aux switches and built in relays, but the accessory calls for a smaller fuse, would a inline small fuse be good?View attachment 53138
That would work, I personally prefer to just change out the factory fuse rather than add another fuse in a fused line.
