ClawSS
I guess still being on the OE battery would be the real culprit in any issues that arise. I see numerous posts of batteries dying. About to get the "cold-snap" here in KY, so will see how it lives through that.
You may be fine Im still on the original batts in my 19 they seem to be doing well in out -40 weather while running my plow also but i do have dual 220 alternators that does helpI guess still being on the OE battery would be the real culprit in any issues that arise. I see numerous posts of batteries dying. About to get the "cold-snap" here in KY, so will see how it lives through that.
Hemis turn over easier than the diesels...especially in cold-cold.You may be fine Im still on the original batts in my 19 they seem to be doing well in out -40 weather while running my plow also but i do have dual 220 alternators that does help
True but my truck is plugged in so its not that much moreHemis turn over easier than the diesels...especially in cold-cold.
With that location low and on the side it could be a physical space issue too. The 220A is definitely bigger than the 160A.The Cummins is not on a separate belt. I bet that's why the Hemi is limited to a 160A on the 2nd Alternator.
It's still probably a good idea to upgrade to a 2nd Alternator for high amp use.
