1FastHemi
With me, It may have been some lag time in the beeping as each tire seem to be different for some reason. Some times it would beep in about 10 or so seconds after I started to let the air out and others wouldn't beep until the tire was almost flat. I guess that might be why I had to do it several times.I was reading the Manuel a bit ago an it said that after you let 5psi out of the tire the truck would give you an alarm sound then you move to the next tire, but didnt you say sometimes the alarm wouldn't come on at just a loss of only 5psi but the tire actually got down to 5psi, or am I all jacked up on Tennessee dew
