That will require an ECM tune unfortunately. It’s set from the factory based on the originally equipped tires’ speed rating.All the above, and adjusted tire size. Also turned off the Cali/Miss. nanny that wont let me have the LED aux light in the mirrors on when moving in reverse.![]()
Still looking into raising the speed nanny as well. I hate it when you go to pass someone and the speed nanny kicks in at 96 MPH.![]()
thanks Chief![]()
Links to solved DIY Sales code mods and common AlfaOBD settings
Here's a roll-up thread for posting links to any successful DIY Sales code mod and AlfaOBD settings required (or not) and common AlfaOBD settings only mods. This is NOT a How-To or Q&A for AlfaOBD or discussion thread. Links and settings only please. TL;DR If you're not here to contribute, you...hdrams.com
I see the setting in Alfa. Haven't tried changing it yet. Not sure if anyone else has tried. It's a bunch of numbers, I think tire rpms, not actual speed.That will require an ECM tune unfortunately. It’s set from the factory based on the originally equipped tires’ speed rating.
Much obliged sir.![]()
only reason i even have fb anymore is for the marketplace and bourbon/ram groupsFWIW, no surprise, there is an FB group that looks to be very active, Ram AlphaODB Users;
If you're into that FB thingy...
www.facebook.com
Several people on cumminsforum and on some of the other forums have tried changing that and ended up with it setting itself to 0, requiring a new PCM to fix it.I see the setting in Alfa. Haven't tried changing it yet. Not sure if anyone else has tried. It's a bunch of numbers, I think tire rpms, not actual speed.
These are the only 2 things i want/need and complaints i have on my new 2025; Coming from a 1500 where it always showed and noticing almost immediately i didnt see what gear i was in and couldnt add it from the menu really bugs the hell out of me. (yes i know i can put gear limiter on) Especially on a HD truck, kinda doesnt make sense to me but idk.fogs on with the high beams, enabled the gear indicator to show what gear you are in
