southern_yank
After several failed attempts of mounting my radio head for my UHF/VHF radio, I decided to make what I was envisioning. Figured I'd share as I know I've gotten many useful ideas from this community.
A little fine tuning to do for version 2, but I'll post them pictures once I get that figured out. version 2 will also relocate the radio body to below the steering wheel behind the cover. I would have had that done already, but thanks to the glorious "engineers" at FCA, nothing is flat, square, or even remotely close to simple to fab a bracket for. So I've got to take the time and 3D scan that area so I can design a proper metal mounting solution for there.
FQTA (foreseeable questions to be asked)
- 2019 2500 Poverty package (tradesman) with cubby below radio - no drawer
- iCom 5100a mobile unit, 100 watt
- Power is run from battery through a hole in the clutch block off plate and routed below center stack
- antenna is mounted on top front edge of rear passenger door - wire running down b pillar under seats to radio - almost invisible - Amazon Bingfu lip mount - NMO with Tram 1180 dual band antenna, short stubby for around town use
- Wire from face to radio is routed into the cubby with a 1/2"Ø drilled into back face of cubby
- Mount is fastened using screws into top face of cubby - I hate this, and version 2 is in process to leverage some alternative factory mounting locations.
- Mount uses standard AMPS mounting pattern with the inclusion of slots to allow for non-AMPS mounting
- Spray paint finish on this as my powder coater was over a week lead time, and I'm impatient
- Just mounted the Auxbeam control today - No feedback on the unit as I haven't gotten the rest of it hooked up or mounted
- I haven't had the truck on any hard or challenging trails to see how truly stable it is, but on washboard dirt roads and standard highway cruising, I love it
- Yes, I will sell these - DM me as I don't know what the procedure is on this forum to be able to sell (mods if this phrase isn't allowed, let me know and I'll remove)
