@1HasBeen can you [or someone else] confirm I am using the right tire pressure?
When not towing, I run 55 in the front and 50 in the rear. By the way, the TPMS system in the truck has never setoff any alarms, which is alarming considering how far below the door sticker I am [in the rear].
How come 55 psi in the front and 50 psi in the rear?
I weighed the truck empty. The front axle was 5,280 and the rear axle was 3,700. I divided those in half to calculate the weight at each tire: 2640 front and 1,850 rear. I looked up the load rating for the Firestone 275/70R18 and determined the front should be at 50, so I rounded up to 55 just to be safe. The chart seems to indicate I could go as low as 35 in the rear, but that seems too low, so I used 50.
Basically, any advice you can offer would be greatly appreciated.
View attachment 4089275/70R18
