Nice! No issues mounting it all under the truck?
had a hiccup or two. need to get a 90 degree fitting for the tank to horn hose and move the blow off valve to the side to allow room between top of tank and floorpan.
this assumes your mounting it where the def tank goes. otherwise I would have put it where the spare tire goes.
So far:
Retrax ProMX
Swing away toolbox
Extruded aluminum tie-down bar / Retrax protection
Door sill protectors
Weathertech floor mats
Future:
Baja Designs Squadron Sport Fog Lights
Baja Designs 20" OnX6+ Light Bar
Baja Designs S2 Reverse Kit
Broke the code.
Measure 1 1/2" down from the inside and cut there at a slight angle
No rubbing or pushing/pulling on the seat required. Works smoothly. Locks in up and down positions.
I did mine today and may have found and eliminated a rattle.
One of my plastic guides was broken and laying beneath the seat. I tried gluing it with no success, so I wrapped it with duct tape.
Ditched the spacers and installed a Thuren/Fox setup. 3" front/1" rear springs, shocks, trackbar, and extended sway bar links in the back. Rides great now.
I’ve got these ordered for my 2023, how do you like them?
Good to know, I also need a little lift for launching the boat on a very gradual ramp
Tried out Chemical Guys Barebones under carriage spray. Gonna see if it helps keep things nice, sprayed the frame and axles. If not atleast it was on sale ha.
Either your truck is brand new or you live in one of those areas of the US not plagued by winter salt like my area. That is one clean under carriage!
