Ended up not going to town. Messed around getting my fiver hitch adjusted up. Had about 5.5 " clearance from the camper to bed rails, so I took the hitch apart an lifted it up 1 notch, so should be setting up around 6.5-7" now over bed. that mopar 30k hitch was more beefy than i thought it was, or maybe it just wipped my a$$. I still think the companion hitch is better but this one seams pretty stought . So a couple things maybe everybody can clear up for me.
1: when I backed under fiver an locked it in an lifted the legs, the air suspension started adjusting. I thought everyone said that you had to plug in before it would do anything???
2: so I got in the truck an the light was on at the alt height toggle. Was it trying to tell me it did something or that I needed to do something??? I did hit the switch, it seamed to go down just ever so slightly. While we were standing outside checking out clearances an lights you could hear the suspension adjusting just sitting there.
3: will the alt ride height do anything when your not hooked to something???
4: after i got everything adjusted , I crawled around underneath the truck to check it out. Found the fuel filters an air compressor, a few body moldings that the little plastic plugs weren't all the way pushed in, do tightened them up. Found the aisin serial #. Anybody know where the Cummins serial # is???
5: maybe I didn't look at it correctly but i thought some had said that the cam plug in at the bumper was capped off. All 4 of my plugs had wires plugged into them. Will be interesting to get the cam an see if there both hot.
Turned 100 miles today , love that truck. How you doing out there John, good fortune I hope.
