You can definitely do the tail lights only and just have the chime, but you’re really cutting out the main feature of BSM. You only get the chime after you activate a turn signal with someone in your blindspot, whereas with the indicators you would probably never even put yourself in the situation where the BSM needs to chime at you.Does this mean I can add BSM by swapping just the tail lights, and not mess with the mirrors? I'm a little leery of disassembling the door panel, and I'm ok with only relying on the chime to tell me something is in the bindspot. If I have the option to install it without mirrors, I can always decide later if I want to swap out the mirrors.
Removing the door panels is a lot easier than it sounds. Popping off the mirror glass is harder than removing the door panels, and even that is pretty easy.
