Oh man, I really need to proof read! Yes I meant 1cm. Thanks for catching that!was 1mm a typo? I don’t think Cutting and welding would be needed to fit 1mm
Haha thanks! I actually just started and trying to learn/practice as much as I can. Its actually not as hard as i thought it would be, i wish i had started a long time ago.Look at this fancy guy and his welding skills... Must be nice!
Seriously, nice job, I'm jealous. I really need to learn to weld.
It’s WAY harder in any uncomfortable position lol looks good tho!Haha thanks! I actually just started and trying to learn/practice as much as I can. Its actually not as hard as i thought it would be, i wish i had started a long time ago.
Oh yea thats NEVER fun especially overhead when you have to be directly underneath due to the location! But when it burns in perfect and pretty it makes it all worth it!It’s WAY harder in any uncomfortable position lol looks good tho!
Wow!!! I want to get to that level! That looks awesome, mine just look like blobs haha…i need to keep practicing..Oh yea thats NEVER fun especially overhead when you have to be directly underneath due to the location! But when it burns in perfect and pretty it makes it all worth it!
I have burned thousands of pounds of wire, dont expect to get great overnight it takes practice. And prep and cleaning is key!Wow!!! I want to get to that level! That looks awesome, mine just look like blobs haha…i need to keep practicing..
I mentioned this a while back in a thread about charging batteries it works quite well and these days pretty much universal as most vehicles have a 7 pin other than small sedansBeen awhile since I posted anything, but figured the latest “mod” could potentially help some folks. I havent been driving the truck much and the recent cold weather seems to have zapped the battery. Figured it was time to put it on a trickle charger.
Initial plan was to run a sae cable from the battery to the rear of the truck, but after some testing I found that the trailer 7 pin was constant hot. So i built the an adapter to be able to maintain the batt using the existing wiring…
Oh man wish i had saw that post it would have saved me the testing , but glad I arrived at the same place, if you dont mind can you please reply with link? By “anti strain” i assume you are referring to the yellow? If so, its actually built up (layered) heat shrink. It allowed for complete sealing and visibility so I remember to unplug before driving off.I mentioned this a while back in a thread about charging batteries it works quite well and these days pretty much universal as most vehicles have a 7 pin other than small sedans
What brand is that 7 pin? I have never seen one with an anti strain like that before
The part that holds the wire in the 7pinOh man wish i had saw that post it would have saved me the testing , but glad I arrived at the same place, if you dont mind can you please reply with link? By “anti strain” i assume you are referring to the yellow? If so, its actually built up (layered) heat shrink. It allowed for complete sealing and visibility so I remember to unplug before driving off.
Yes thats correct just a cable gland."The part that holds the wire in the 7pin"
isn't that just a cable gland , waterproof wire pass through?
you added that i assume? Here they are referred to as an anti strain i have never seen a 7pin with one but its a great ideaYes thats correct just a cable gland.
