That will just mute the horn, meaning no horn at all.This should also take the horn off the canbus, so no more delay to sound the horn? And you can just give the horn a short little bump instead of the second or two minimum blast?
I thought part of this mod rewires the horn so that the BCM is no longer in the loop. When the horn switch is pressed, the horn is sounded via the VSIM output from the horn switch triggering the relay, instead of the BCM triggering the relay. Did I get that part wrong?That will just mute the horn, meaning no horn at all.
You would have to ask @mountainears about that behavior. I would think it would still behave the same because the VSIM is still using a bussed input.I thought part of this mod rewires the horn so that the BCM is no longer in the loop. When the horn switch is pressed, the horn is sounded via the VSIM output from the horn switch triggering the relay, instead of the BCM triggering the relay. Did I get that part wrong?
We may not be talking about the same thing. Are you talking about the original post, or the one directly above yours?I thought part of this mod rewires the horn so that the BCM is no longer in the loop. When the horn switch is pressed, the horn is sounded via the VSIM output from the horn switch triggering the relay, instead of the BCM triggering the relay. Did I get that part wrong?
Original post.We may not be talking about the same thing. Are you talking about the original post, or the one directly above yours?
Nevermind then, I misunderstood.Original post.
No, unfortunately (or fortunately depending on your plans) it’s all through CAN.Got it. I thought that the diagram was stating that the pin out on the VSIM was directly coming from the horn switch.
This is fantastic and should be included in the document on the how -to for this mod. I eventually figured it out (by testing the horn) but could have saved a lot of headache if these pics were in the document.Found a picture. It actually has numbers on the back. What is a little confusing is that not all the sockets are populated so you can't just count 8 wires. Here's the photo I found, it shows the wire circled and a cropped version where you can see the numbers at the top (8 and 10)
