Deltron
I noticed the EVIC DPF gauge always reads zero (22 Cummins HO). When I picked up the truck it was reading maybe 20% and went to zero within 100 miles. It's never registered anything since. Any fix?
Also my Scangauge II has odd readings. The truck regened and when it was done it said 40% DPF load. The next morning when I started it it said 23% but very quickly went back up to 40%. Seems a bit weird like the truck isn't reporting correctly. Also the Scangauge says 74% when I fill the truck with DEF but the dash gauge says full. I don't think the Scangauge is faulty since it works perfectly in an '18 Cummins.
Towing heavy the truck's first regen was at 1,100 miles. My guess is if it only goes back to 40% it'll probably be every 600 like our '18 was. DEF usage was around 3.1%, considerably more than our '18.
The engine is considerably quieter than the '18 and doesn't feel like a farm tractor at lower RPMs. Maybe that's due to the Aisin instead of the RFE, I have no idea.
