dstonic
Sounds good…presently I have 14,000 miles on the Nexums and somewhat concerned…plan on a 2500 mile round trip with camper.Michelin defender that’s what I’m gonna go with on my 22 DRW when factory tires give out.
I second this. The ride has been the best on the Cooper Discoverer AT3 XLTs.. BFG, Michelin, and Toyo did not compare to the ride quality hooked up and empty. Not sure on how long they last, got rid of the truck when the 22 came in, but they will go on the 22 as soon as the OEM's are gone.I like my Cooper Discoverer AT3 XLTs. Good traction on snow, wet, dry n quiet too. I'm very aggressive behind the wheel and they are holding up great for me after 16kmi. . Falken Wildpeak is another one I would look at. They are super popular across multiple forums. They are the tire i should have put on my 17 JK. I went with Nitto Ridge Grapplers and they just don't perform well once the roads get moist. This is all assuming you are thinking about an A/T tread design. Happy Hunting!
I hear you.....but I wanted to keep the white wall letters to match the rear.....also my inner wheels are steel and not polished aluminums like the outsides. Althougth I know I can have them remounted again (keeping in spirit of your suggestion) which is one that I am thinking about.No reason to have matching tires on a dually. You can only rotate side to side anyways.
Also, on DRWs, you usually have to replace the fronts first. You just need matching tires on an axle.
Depends on where you are and if its 4wd. One province here you cant run miss matched tires idk if any states have the same lawsNo reason to have matching tires on a dually. You can only rotate side to side anyways.
This doesn’t exist down here in USA. What a stupid law.Depends on where you are and if its 4wd. One province here you cant run miss matched tires idk if any states have the same laws
I wouldnt do it due to the small differences in circumference if in 4x4 mode. some tires are 1/2 inch bigger around than the same size in another brand.This doesn’t exist down here in USA. What a stupid law.
I can see mismatched tires on an axle, but entire truck? Stupid.
