This is not the right interpretation of the issue. Needing to teach an employee at a dealership how to read a document is a massive oversight and liability. Teaching the person how to use the document is another matter. What we're talking about is the former.
Memorizing the codes is not the issue at hand nor would the codes need to be further specified in the document. After all, it is specifically a code reference. The lack of a key to define the shorthand jargon is the issue. I called three dealerships today to ask what the abbreviation means and I received three different answers. While talking through the options annotated with M/H, one person told me two codes are incompatible when, actually, they are required to be added at the same time. I'd call that a significant misunderstanding, which is why technical documentation is supposed to be self-referential regarding the embedded terms.
It is not relevant if one is employed at a dealership when reading the document; while the uninitiated reader should not automatically understand the complexities or nuances of configuring a vehicle, which requires domain-specific knowledge, all readers should be able to understand the language and terms. Even if you disagree with the standards for technical documentation, the failure of the definitions to be included is causing misinformation to be spread through dealerships. There are definitions in the footer for the other abbreviated terms that appear on almost every page. An additional minute could have been spent on the document to clarify the confusion, which is, as I said initially, lazy.
From a business perspective, pissing off one customer by failing to define a term is an easy mistake to avoid. After today, I no longer have confidence in dealerships to interpret this document unless they are configuring a truck with a piece of software that provides real-time validation. I still won't buy a Ford, though.
