Installed a Lomax tonneau cover - I couldn't get it to seal 100% at the tailgate, apparently the newer Rams will have 1-2mm of space there. Still like it a lot and this particular finish is similar to bedliner.
Pelican BX80 cargo case + universal side mount - Has a lot of potential but expensive and CS is kind of lacking (came packed with wrong carriage screws and CS kept giving me the runaround, ended up sourcing some longer carriage bolts through another company). May use ROAM in the future.
Mounted a dashcam, on the dash - Used Bullet Point base, 67D arms I carried over from my Jeep, Tackform Bar Mount (1.25"), and a Blackvue 750X Plus camera. The Ram 12V cig/plugs are the same as the current generation Jeeps, you can get a 12V adaptor (https://www.amazon.com/gp/product/B0886DNNSP) and add a switched or constant power source. I have it set to power on with the truck, no parking mode when off. There are already holes on the top console that you can enlarge (or not) if you need to pass cables through.
Would like to talk to you about the lomax cover
Not the OP, but I had one that I sent back because the seal/fitment was unacceptable. Loved it on my 1500 but the 2 piece rail design just doesn’t lend itself to a quality fit.
I’d love to run a decked system but can’t use a gooseneck with one so no go for me.
i really wanted their truck box...sits too high for the GN as well....even emailed them to see if theyre going to make a low profile version and they said they were they just didnt know when...itd really be awesome if they made something for the jeep so i didnt have to get the goose gear stuff....
What plug did you use in the bumper
You can by it on Amazon not expensive. Had to lengthen the original cord on the back side with a short extension cord. Taped up the ends behind the bumper to water proof the ends to keep the salt out and tie wrapped the cord on back side of bumper.
meh…put a pin switch for the overhead light on the snugtop’s hatch. The last had one, it’s been bugging me in the hunting field when the bed lights turn themselves off.
I was told by my social events coordinator to load the pumpkins up, so I did. I think the plan was to carve them at the in-laws
But, I also loaded up the single shot nerf guns because Training is important right, @AnthonyD1978 ? So no pumpkins were carved because shooting is funner
