Yeah, I need to get over it and just drill the plastic. There are two connectors coming down from the bed lights. One is the switch, one is the light. I will poke around, but just in case, anyone know which is which?I’m thinking I’ll probably put mine in the plastic, just have to get some time off work to get it done… I can’t see a good way to secure it otherwise…
I am thinking that I can attach the led bolt to the step bracket, located like this. zip ties won't cut it, so need to figure out a way to more securely attach it. Alternatively, I could drill a hole in the plastic bumper and mount the bolt led there, just not sure I want to do that.
I don't think you'd notice the big one either, since you can mount it facing directly down. Reluctant to open it up and test it since I plan to return it. I think the small one will also be more subject to being completely obscured by crud.I think the small one would barely be noticed in the plastic when it’s off, wonder what the actual light output is
