How is the ride compared to stock?Yes, have had the kit installed for about 3 years now and no complaints. Drives great and would use it again. Don't think you can go wrong with any of the top names, Bilstein, Carli, Thuren.
I would say it's better then stock but it's been a long time since I installed it and I am running larger tires which helps as well. I have no regrets going with this kit.
What size tire are you members running with this leveling kit? I'm thinking about a 35 or a metric that measures around 35.5.
I recently installed the Bilstein leveling kit with all four 5100 shocks. I can say that the ride is slightly better but nothing significant. I did have the off road package with the 4600s so it might be more noticeable if you don't have it.
I'm running Nitto Recon Grapplers 35x11.5-20
I don't have any pics of the underside.Nice, post a picture
I don't have any pics of the underside.![]()
Thanks. The rear is stock height with Bilstein 5100 shocks.Holy cow that looks great. What did you do for the rear?
Here is mine. 2.3" bilstein level in front, 1" spacer in rear to bring a little bit of the rake back. 305/70-18 tires, 18x9 +18 offset wheels.
Did the 2.3" Bilstein level your mega cab? Reading the Thuren tech info it says to use their 2.75" for the mega cab since it is heavier then the regular crew cab. I'm so confused!
Nice! What is the part number on the 2.3" springs?
www.suspensionlifts.com
