www.cjcoffroad.com
^^^ This ^^^There’s always this option:
Baja Designs Dodge, Ram 2500/3500 (19-On), Reverse Kit, S2 Sports W/C
The 2019-On Dodge Ram 2500/3500 Dual S2 Reverse Kit has your back! If your stock reverse lights are not cutting it in the dirt or in your daily life, Baja Designs has a solution for you. This kit comes with everything you need for a simple installation that provides a huge upgrade to your stock...www.cjcoffroad.com
Care to detail how you wired this up for the duel operation?I used Baja Designs rear bumper brackets and Nilight 6.5" LED Bars (and Auxiliary Switch #2).
Wired so when shifting to reverse, this will turn on the truck's backup lights and the rear LED light bars. Or, when Aux Switch #2 is activated, only the rear LED light bars are turned on
View attachment 28827.
It's detailed in the attachmentCare to detail how you wired this up for the duel operation?
https://www.vleds.com/lp-reverse-72-w-5500k.html
This works fantastic and just wire it in to your trailer harness with a splitter.
your aux switch is probably set to a constant 12v, you need to change it to 12v on with ignition. you do that in the evic settingsJohn,
I followed these instructions to a T, except I chose to only have them activate with aux2 and not with reverse lamps. When I plug the jumper harness in under the dash, my backup lights stay on constantly.
Any idea what I did wrong?
Your
I'm in Oregon trout fishing, don't have that instruction with me. Just go into your Evic settings and select the one above speedo
Just verified on EVIC. I have the choice between latching/momentary and batt/ignition. I want batt on my lights cause sometimes we unload at the cabin and don’t need to idle the truck but want lights.
I’m thinking something has to be wrong at the jumper plug under the dash. Anyone wiser than me able to help?
Jumper between 1 and 6 was cut. 1 was spliced to 5.
Is it bad to run the extra LEDs off both the reverse circuit and an auxiliary switches since it may back feed without a diode?
