cdntrucker
Yes, support from underneath the tank but there is no plan at this time for a strap to go over the tank. Due to the design of the tank there seems to be no practical way to use a strap from the top side for securing the front of the tank.
The plan is for the support to hug the tank on its inner side and this should provide lateral support equivalent to a crossmember mounted strap. It will be mounted using an anti-chaffing rubber (photo included of the Titan approach) to provide an even tighter fit than simply metal on plastic. The inner side of the bracket can be up to 9" high to match the front mount crevice of the tank.
Yes, we can confirm that measuring from the center of the rear strap to the center of the front strap is 42" and this lines up well with the intended bracket mount location.
