So do you think it would be better to go with an aftermarket group to get the install down. I only want the gooseneck option, I don't plan on any 5th wheels at this time.Ordered mine with 5er-gooseneck prep package and it came without. Didn't notice when picking up my truck, ordered with toneu cover so didn't look under. Went back to see the dealer and installing this package after a fact was too complicated through RAM. Got it all installed by an independent hitch shop and got reimbursed by my dealer. As a bonus the aftermarket gooseneck (gooseneck and 5er are separate packages even through RAM) came with a ball and drop in chain anchors.
The reply wasn't to you.How is my wiring improper?? I've got a functional trailer plug in the box plus a functional plug near the rear license plate?
Also 've got the bed plugs and everything else, no different than the factory install
You get the 4 pre drilled holes for a 5th wheel hitch to drop into, the single center hole for a gooseneck hitch and the 4 and 7 pin plugs on the side bed wall to plug your trailer into. No hitch in that package. You can get a 20k non-slider 5th wheel hitch as another option if you want.
Ah yes, you are correct, its the 12 pin camera plug vice the 4 pin trailer connector. You also get the 115V bed outlet as wellIf the truck has 360° camera or you have any trailer camera wiring options, the 4-pin will not be there and it will be the 12-pin trailer camera plug.
The 20K hitch is a Curt Q-series (based on pics I've seen). I'd take a pass on that one and get either a B&W companion, or the Curt A25 (I have an A25 and love it.)
The DRW max tow comes with a Curt A30. I've not seven seen that available from curt so I suspect it's just the A25 "uprated." somehow.
I think the 115V bed outlet is pretty much standard on all trucks now since 21?
So are you all saying I would still have to buy the hitch assembly that gets mounted under the bed as well correct? Not just the ball and/or chain anchors themselves?
