DIY DPF cleaning?
LenTex
Leander, TX
Any suggestions on a good chemical DPF cleaner that I can somewhat easily do myself? I’m not ready to give it an exhaust diet yet and I’m not comfortable with cutting it out, pressure washing it and re-welding it myself.
I’m getting 12 mpg with a lot of highway, high speed driving, and very frequent regens. The truck’s previous owner had 1/3 of the hours in idle, so I’m thinking the thing is pretty clogged. 2020 standard 6.7 with about 65k on the clock.
Thoughts? If I need to give you more pertinent information let me know.
the only way I've seen it done is at a local shop that specializes in dpf cleaning. it's a fairly interesting contraption they hook the dpf up to.
Im a diesel machanic for Peterbilt, i deal with alot of aftertreatment issues. DO NOT put any liquid through your dpf or scr. the cleaning process consists of 1200 degrees for 8 to 12 hrs in a large ceramics oven, then 120 psi air pulse machine to clear the ash from the doc/dpf only! scr cannot be cleaned. we have had customers attempt to "wash" docs and dpfs, but as soon as the liquid/water starts to steam when heated the core cracks/shatters/melts.
We use a radiator shop. Its reasonable. Get new gaskets, they aren't reusable.
Thanks for the heads up. Any suggestions of where to get it done right?
