Finally something for us guys that like shiny stuff.
Looks good. I have the front Thuren HEMI springs and 4 shocks ready to go. Also have the Battleborn wheels in the same specs as yours. I had the G2 on my 1500 and will put 285s on this one. Good tires. These pics give me a real good idea how it will look.18x9 Method 305 HD's w/+18 offset
285x75xR18 Nitto Terra Grappler G2s
Thuren 1.00" coil springs up front
View attachment 42862View attachment 42863View attachment 42864
Rough Country. The kit is for a 1500 and doesn't work with a 2500 grill. I fabricated my own mount to stabilize the lights in the grill.What lights do you have in your gri
Nice Ram !!! Thats the look I'm after and looking at the 2.75" Thuren on my Mega Cab. Did you do anything in the back and is your truck level or nose high ?Method HD NV 305 - 18x9, +18 offset)
Toyo Open Country R/T - 37x12.5x18
Thuren 2.75" Leveling kit w/Fox 2.0 IFP
Those are Innov8 Racing Beadlocks. Expensive wheels, but are great.what wheel is that? looks fantastic
Have any additional photos of the grill lights? Any mounting suggestions? Will i need to cut the grill?Rough Country. The kit is for a 1500 and doesn't work with a 2500 grill. I fabricated my own mount to stabilize the lights in the grill.
How do you like that offset? Any trimming needed?Fuel Vapor 20 x 9 plus 1 offset on 37 x 12.5 20 Nitto Ridge Grappler
I love the looks of the 1 offset, tires stick out around 2 inches past the stock fender flares which gives it a good stance without over doing it. The shop cut off a few inches from the wheel liner so I assumed it rubbed there but it doesn’t rub anymore even at full turn.How do you like that offset? Any trimming needed?
I wanted to drop down to a 18" Fuel Covert to improve the ride a bit but, in 18" they only make it with a 1mm offset. I wanted between 18-23" offset but, will need to go up to the 20" wheel for that - at $100 more per wheel.
