Zeus2018
Directions make it look pretty straight forward and plan on dialing in my own alignment.
Some confusion on the radius arms however. Should I loosen all radius arm bolts (axle and frame) while weight is off the suspension, and then re-tighten under load?
And I believe Caster is also adjusted under weight as well?
Any advice would be great, thanks!!
