TheNinja
I recently moved to a Ram 2500 from a 2000 Ford Excursion. To have a fairly level single axle trailer loaded with my side by side at under 4000 lbs I used a 6 inch drop with the Excursion. With the Ram, the 6 inch drop leaves the back of my trailer 9 inches off the ground and the front almost 20 inches off the ground. I'm looking at getting a 10 inch drop to even things out more and wonder if anyone has advice or experience they can share. Do i get a class 5 hitch that has an adjustable drop or do I get a class 4 that's not adjustable but would require me to use the reducer sleeve. Is there an obvious answer or is it preference and I'm over thinking it?
