Which floor jack and stands do you guys like (for tire rotations, etc.)?
For roadside I like my aluminum aceon jack (with a bigwheel kit installed from 911motoraports). For around the shop I have old steel harborfreight and noetherntool jacks.
@IowaPW hey how do you like the Atlas mount and balance machine? Once I get the addition done on my shop, I’ll be adding some tire machines as well. You happy with them?
Yeah...really like them. I've had them for 18 months or so now in my home shop. I do maybe 1 set every month or so.
Going to revive this thread.
Is 3 ton going to be enough to jack up the front under the front diff? Not just the side for a front complete? Or am I going to break things this way?
I need to upgrade my jack my old 1.5 tons don't cut it anymore, too small and too short
I use a 2.5 Ton.
You can jack under the diff, but it will take a lot of vertical to get both front tires off the ground if that’s your goal.
I generally just lift the from under the control arms.
Why just 1 lift when you can have 9?
HF jack a bit different but works well.
That's the one I've had my eye on recently. Currently have a 3 ton Daytona that I've had for 4 years now and love it.
