Having been a loyal Chrysler customer since my first 1993 D350 Cummins, it's not surprising anymore. Unfortunately although the ball valve works to keep the air box temperature down and the AC vent temperature lower, I'm not sure how that affects the cooling system pressure on the hoses and what warranty denial they may implement if seen by a dealer. Loved my 2017, the 2021 maybe my last.It sure would be nice if Chrysler came out with at fix or TSB on this issue. It's sad that you have to find a fix on Amazon, but at least it's something.
Those lines to the manifold are aluminum, they are your air conditioning lines.Still wondering if someone can tell me what that manifold and steel pipes are in the 1st photo of the previous post? (Blue arrow, 1st photo)
But just an addition to what I encountered when doing this: The hardest part was just getting my hands into position to disconnect and reconnect everything. The space is tight. Also, I did purchase a gallon of coolant to replace what is lost during the process. I did not need it however so now I have a gallon of coolant that hopefully I will never need! As can be seen from the below photo, I lost only maybe 2 or 3 oz, maybe 4 during the disconnect. Almost nothing flowed out of the engine side and if you don't let the hose from the heater core hang down, very little comes out of there either.
Thanks! I felt the smaller line after running the engine and A/C for a while and I don't think the heater core hose resting against it will be an issue. The bigger tube changed temperature quite a bit but the smaller one did not. Mainly I wanted to be sure that smaller tube would not get hot and damage the wrap of the heater core hose so it should be good.Those lines to the manifold are aluminum, they are your air conditioning lines.
Do you have a link with the parts you used? I like how clean yours turned out.. not really a fan of the added hose/clamps of the muzzy kit..I removed that black fitting with the 90* quick connect fitting and put 3 1/2" pipe with a right angle ball valve in it's place. Tight fit but works great!
For those who have installed the Muzzy AC hack and have had it for a reasonable amount of time - have you experience any leaks? Seems to be the most common complaint, with hose failure being second?
I bought a the pieces myself. I used 1/2" galvanized about 3 1/2" long and a 90* Parker Hannifan 1/2" ball valve.Do you have a link with the parts you used? I like how clean yours turned out.. not really a fan of the added hose/clamps of the muzzy kit..
I am interested in doing the Muzzi mod on my 2021 6.4 Hemi. At first glance it appears though that the coolant line leaves the water pump to the heater core and then circulates and back down to the oil cooler and from there it ties in to large hose that goes back to radiator. Seems like a valve interrupting circulation would be a problem for the oil cooler. Anybody have any experience with this? Thanks for the help.
Just for info. I traced all these lines out on an engine sitting in a crate at the dealership ready to be installed. Cutting flow to the heater core will not hurt anything. If anything it will INCREASE flow to the EGR cooler and the TURBO. Just my opinion. Plus the evidence of hundreds if not thousands doing this and the fact that majors like Amazon sell the kits. etc.
I don't even have my truck yet, but battling this 100* heat wave has me nervous about my soon to be Ram's AC issues. I also got the 6,4 Hemi, so if you found an answer to inproving the AC would you please share. Continuing to look myself.I am interested in doing the Muzzi mod on my 2021 6.4 Hemi. At first glance it appears though that the coolant line leaves the water pump to the heater core and then circulates and back down to the oil cooler and from there it ties in to large hose that goes back to radiator. Seems like a valve interrupting circulation would be a problem for the oil cooler. Anybody have any experience with this? Thanks for the help.
FWIW; has FCA not addressed this issue being that it is almost 4 years old now?
Yep, that's TSB 24-001-20 with a date of Nov. 5, 2020 for 2019-20 year trucks as you say. So unless RAM has redesigned the A/C (has it?) then I would think that TSB should be extended to 2022 trucks.There was a TSB for affected 19-20 trucks that replaces the HVAC box and uses a different blend door design.
I had mine done and it definitely improved. I guess some are still not happy with the performance even in the new trucks.
