dtsequeira
This would be cool if it comes to reality.
I had one for a week as a loaner it was awful on fuel but the power was there7.6l and they would have my attention.
The 8.0l V10 screamed no replacement for displacement back in the 90s...lol
I have owned mine since 2009. It gets 10 doing about anything....16 if I can keep it in 5th gear on the highway. It is still my favorite truck. The 6.4l feels faster...but put that 488 cu in Magnum in first gear and let out the clutch...she pulls so beautifully at just idle.I had one for a week as a loaner it was awful on fuel but the power was there
I'm not sure a turbo gas HD motor would be that much cheaper than a diesel really. You still need a turbo, intercooler, high pressure fuel pump, more expensive pistons and valves, cool-down water pump, bigger radiator and oil cooler etc. etc.I think its about time someone built a turbocharged gas engine for the HD trucks. Too me it always seemed like a big gap in their lineup. Having a natural aspirated gas engine for the base engine, then offering a turbo diesel as the step-up engine left a lot of room between the two. Frankly Ford found a market for a step-up gas engine with the 7.3L v-8. I think ram could easily offer a 6.7 turbo gas engine for significantly less than the diesel, and I would never look back and buy another diesel. The thing that has kept diesels alive this point has been a lack of a credible gasoline alternative and turbocharging (for the power hungry). There is no reason you can't build a cheaper gas engine to have nearly diesel levels of torque. I'd be happy to give up oilly pumps and looking for DEF and loss of payload. Heck I wouldn't mind a hellcat motor, slightly detuned. Ever driven a non-turbo diesel, omg they are so pokey.
And the 3.5 is a $2,700 option. The reason they can get that little of a price increase is because around 60% of F150 sales are ecoboost. That 60% is probably more than the total of all HD Ram sales every year. I would bet a HD turbo engine would be a $4,000+ option(Ford 7.3 is $2,000).I agree a turbocharged gas engine won’t be as inexpensive as a non-turbo. On the Ford F-150 the upgrade price to go from the non-turbo 3.3 v6 to the twin turbo 2.7 v6 is $1285. That data point would seem to indicate turbo charging isn’t that expensive. Then factor loosing the dpf and scr it seems like a no brainier. Btw a hpfp isn’t required for a turbo engine. You can use port fuel injection on a gas car.
I don’t think this changes my point a lot. I think it’s a major miss by the manufacturers to offer a turbo gas engine with the torque diesel owners like in their turbo diesel. Without quit as much torque and at a price less than diesel. There are a lot of people I think who would like a turbo gas motor but don’t want to jump to diesel.
Also hp will be significantly better than the diesels with that instant low end torque many diesel owners like.
I'm with you. I'm really curious if the new twin turbo i6 makes it to the HD line. Or a variant of it. If the numbers are there, I would switch in a heartbeatI think its about time someone built a turbocharged gas engine for the HD trucks. Too me it always seemed like a big gap in their lineup. Having a natural aspirated gas engine for the base engine, then offering a turbo diesel as the step-up engine left a lot of room between the two. Frankly Ford found a market for a step-up gas engine with the 7.3L v-8. I think ram could easily offer a 6.7 turbo gas engine for significantly less than the diesel, and I would never look back and buy another diesel. The thing that has kept diesels alive this point has been a lack of a credible gasoline alternative and turbocharging (for the power hungry). There is no reason you can't build a cheaper gas engine to have nearly diesel levels of torque. I'd be happy to give up oilly pumps and looking for DEF and loss of payload. Heck I wouldn't mind a hellcat motor, slightly detuned. Ever driven a non-turbo diesel, omg they are so pokey.
The new engine would also be able to be adapted to hydrogen AND other fuels apparently and also but here is a guy who is a mechanic in Canada with a lot of experience specifically with the 6.7 Cummins in many different vehicles and a Power Wagon fanatic (6.4) and his discussion on what the advantages and disadvantages and probability of a gas version might look like. He basically thinks it is a distinct possibility as it would be surprisingly easy and inexpensive for Cummins to do this...
It is very likely it will produce great numbersSo it's the same rotating assembly, gas has slightly less energy than diesel.
What's keeping this 6.7 gas engine from producing near the same hp/tq as the diesel version? I assume compression ratio difference?
I owned one, was an extra cab dually. Pulled like a tank and drank gas like a tank.7.6l and they would have my attention.
I still own mine. It is still the most powerful GAS engine RAM makes. 450ft lbs if torque...21 more than the 6.4l and much, much lower in the RPM range.I owned one, was an extra cab dually. Pulled like a tank and drank gas like a tank.
The price of gas was cheap then so not a big problem. Was worth the cost for the power. It had the highest torque and horsepower of any pickup truck. And in the Viper it was an awesome powerhouse.
