Basically his tunes are so raw it shows how little he knows about tuningSo, you are saying when his customer needs him the most, he disappears? Not good.
Raw?Basically his tunes are so raw it shows how little he knows about tuning
No fine tuning or defining its basically the same crappy tunes like the stuff you would get from edge boxes or any of the one size fits all tuning but of course his prices reflect thatRaw?
What tune level do you run your CCS at day to day?No fine tuning or defining its basically the same crappy tunes like the stuff you would get from edge boxes or any of the one size fits all tuning but of course his prices reflect that
With fuel at 2.50/L here i run it on economy tune 45hp its more than enough for daily driving on stock tires for my 7 min commute lolWhat tune level do you run your CCS at day to day?
No it does not i believe the tunes are the only thing locked but i could be wrong i have heard of others doing it for 2 vehiclesIsn't ez lynk locks into a VIN?
How would you use it on 2 vehicles is that's the case?
Efi is good for 600 vehicles at one time only the tunes are vin locked…Well should have looked into this before making a switch. EFI Live can be used on up to 32 vehicles I believe (I think it says so on their product page), others lock into VIN. That's why you don't see any newer programmers for sale by themselves, they're just paperweight when removed from a vehicle they were used in.
Welcome to the dark side of quality tuners, proven is not badSwitched to Proven. Detailed and proper review will be posted when I have the time and even more experience. But I will say, night and day difference in every good way. 0 lugging, more power, cleaner overall in feel, sound & fuel delivery (near no smoke but more power even in lower ''HP'' tune levels than Optimal. Wow is all I can say every time I drive the truck these days. So thankful I did it. Also, I have both Optimal and Driven on my EZLynk in case anyone wondered as I did previously if one would delete for the other to be put in place.
jalopnik.com
Have it flashed to stock from the dealer then load your own tuner/tunes of choiceStumbled upon this forum/thread looking for an answer. What tuner/tuners be able to overwrite and basically install my own from scratch? 13 ram 6.7L it’s del/tuned but prev owner didn’t include tuner in the truck when I got from dealership.
That going to mess with how the truck runs or just throw CEL? How much they normally charge for that? Was told that the ez lynk can reset to stock…that but true?Have it flashed to stock from the dealer then load your own tuner/tunes of choice
I'm not sure if there was a "limp" mode on the '13 but this is what will happen to 19+. It will obviously throw a CEL and will give you a warning that it will go into a limp mode in XXX miles. Depending where you live you should be able to make it home without any headaches. But folks with tuners usually reload their tune while on dealer's lot.That going to mess with how the truck runs or just throw CEL? How much they normally charge for that? Was told that the ez lynk can reset to stock…that but true?
