Linked4door
Any one add any to their truck yet? I am trying to get some input on where/how to mount them. Also trying to see what brands or types are recommended.
Thanks, this is what I was looking for. Any closeup pics of the grill to show how you mounted them? Also did you replace your tow hooks with fog lights?I have added four flashing lights to the grill, a Amber/Green light bar on the roof, and a blue light bar in the back window, and a Green dash light bar. I work with the Patriot Guard here and
they are only used for veteran funeral processions mainly for getting peoples attention. Doesn't help all that much really since most seem to have no respect for a funeral procession any more.
Don't have a VSIM, but have been reading up and debating whether or not it's worth adding. Didn't start this job till after the truck was ordered and delivered, or else I would have added that option from thr factory.If ypu have the VSIM you can run the front and rear factory lights as wig wags i do it when plowing i also have a blue beacon up top here the wig wags are not enabled
I bought mine from the lot and didnt think id need the VSIM but it was on the truck and now im glad i have itDon't have a VSIM, but have been reading up and debating whether or not it's worth adding. Didn't start this job till after the truck was ordered and delivered, or else I would have added that option from thr factory.
That worked out pretty well. If my teuck ends up needing a motor, I am going to order a new one with VSIM. Some of the Feniex lights I have been looking and seem to be able to tap into the wig wags optionI bought mine from the lot and didnt think id need the VSIM but it was on the truck and now im glad i have it
Do you have details on how to do this? I ordered my truck with VSIM.If ypu have the VSIM you can run the front and rear factory lights as wig wags i do it when plowing i also have a blue beacon up top here the wig wags are not enabled
found thisDo you have details on how to do this? I ordered my truck with VSIM.
The 4 lights in the grill fit perfectly in the openings and are held in place with zip ties.Thanks, this is what I was looking for. Any closeup pics of the grill to show how you mounted them? Also did you replace your tow hooks with fog lights?
Does the rear window light bar have any light bleeding inside rhe cab or where you able to seal it to avoid that? Would you be willing to get pic to show how you mounted it?
thats interestingDoes a rear dust/chase light count? LOL Joking, but I do think it is a safety addition for my use though.
